Nighster parts on older sportster?
I was checking it out when I was looking for a project bike. I decided on a 2003 XL1200C simply because I have a 2003 XL883C. I ran across it when I was looking in to the same tank swap but never paid too much attention to it because it looks like a simple part to make. A block off plate that seals the tank & has provisions for a left side pet **** is an easy task...but then I found the same tanks brand new without fuel pump accomodations...so then I really put it out of my mind.
I'll keep an eye out for it & if I see it again I'll post a link.
As far as a 2002 I am not sure but I know the Nightster tank has different mounts than a 2003.
Now that I think about it...it would make more sense to paint your current tins. To use a Nightster tank the mounts will need to be re-worked, I would feel safer welding the block off plate in & welding a petcock bung in that plate. But you would not have a reserve unless you welded in another bung for it. Then re-seal the tank...and remove & weld the nipple hole shut...painting the tank you have or even buying a brand new tank from a non-hd company and having that one painted would probably end up less expensive considering shop rates for labor alone for the mod.
