brake light issue
brake light issue
my brake light is not coming on when i use my front brake, but working fine for the rear brake. i have checked the fuses and everything is good, so i am thinking it's a bad pressure switch up front.
any other thoughts before i pull the trigger on ordering a new one and putting it in, anything that i am not thinking of that could be causing it
thanks
db
thanks
db
front switch goes bad often, new one will too. bad design on the contacts inside, try cleaning with electrical parts cleaner, its not a pressure switch.
your going to deal with this many times, some people forget about it and use the rear only for the life of the bike, comes with the territory.
what is pattern you reference for the tightening the housing screws? there are only 2, i can't imagine the pattern really makes all that much of a difference as long as the brake/master cylinder housing is tight/flush against grip housing
The switch has a tiny plastic piece that protrudes through a rubber boot. The brake lever has a point that pushes on that plastic piece. When you pull the lever it lets the switch out, turning the light on. If you break that tiny plastic piece off the switch (because you were changing grips, switch housings, etc.), the brake light stays on. Happened to me once - right after I succesfully ran my wires inside my handlebars. I really didn't want to take my bars all apart so I cut the head off a 10 penny nail and epoxied it to the rubber boot. Ghetto, but it still works like a champ after two years.
Sounds like you got a bad switch/loose wire, not a broken piece.
