Clutch adjustment
strait forward like ya said, give all the slack in your cable, pull the derby, adjust, put it back on and take up the slack in the cable. also adjust your primary chain while your there or at least check it. and change yr primary fluid, if yr not gonna do that adjust while the bike is standing up and ya won't spill any fluid
1 Post
That video is diff then the sportster.
Loossen jamnut on the cable to introduce a large amount of play in the clutch lever
Pull the derby cover, remove hex nut and spring..turn stud counter clockwise until you feel resistance then turn clock wise 1/4 turn.
I used vasoline on the gastget to hold it in place when i put it back together.
Tighten cable, and jamnut with 1/8 play in it.
