HELP!!!!!! Iorn want start............????
When did they introduce this feature? I'm guessing 2007 with all the other additional electronics for the EFI....
And AKracing don't feel dumb, it happens to the best of us. Wont happen again I'm sure haha. Next time you will know what the problem is right away. Enjoy the bike!
Not sure, but I assume 07 as well. Seems like a good idea anyway. If mine didn't have that feature I would have crapped my pants a couple times starting it in gear.
Received 1,272 Likes
'07 Nightster won't start in gear unless the clutch lever is pulled in. Found out when I installed the suicide clutch. Now I gotta go trace the wires, then jumper them at a terminal block/strip somewhere. You run a suicide, you'll stall at a light sooner or later. Nicer to just push the foot clutch pedal in, hit the starter switch, and go, rather than have to find neutral with the jockey.
It ain't a "huge deal"; it's just another PITA. Sounds like another "heavy hand of the gooberment" deal.
Yeah, it's a newer feature. With my '09 if it's in gear and you try and start it without pulling in the clutch it will do nothing...wont even jump.
Don't know about the rest of you guys but shouldn't it be second nature to clutch before starting regardless of what gear the bike is in? it is for me, even when I see the green light on I still clutch, I don't want to find out the hard way that my bike does start in gear with out clutch, knowing me I'll end up dropping it.
