mounting bullet headlight on Nightster...need ideas...
Just need some guidance, I cant seem to fit a drill to make a hole... anyone have a details on how to mount the 3/4" block to the lower brace of the front end. I tried a search, but came up unsuccessful...Thanks
Alright got it all in and mounted... does anyone know how to make the stock headlight fit in the same housing... I got the 5 3/4" flat black bullet style headlight from drag specialities. It seems to be a hair off from fitting anyone have a trick....
If your talking about the mount for the new headlight, i had to take the grinder to the sides of the mount until it fit just right.
I dont think so, maybe a better description is needed... I got the headlight housing mounted, I am trying to make the stock HD headlight fit into the aftermarket housing. It all sits correctly but the front cap that goes onto the after market housing doesnt sit flush. The stock HD light is a tad bigger than the end cap that sits on the front of the housing. I know ive seen some guys run that same housing with the stock HD headlight(not the bulb, the glass housing). I think a guy name Slackster has it done.. not sure how he did it thou.. I took a grinder to it, but dont want to ruin it.
