1998 Sportster 1200S Clutch Basket Rubbing Shifter Shaft?
Hey,
First off let me say I am new here and this is my first post.
I have a 1998 Sportster 1200 Sport. It has 23k miles on it.
I just did a complete top end rebuild with new 10.5 to 1 wiseco pistons, new hd lifter tappets.
Well here's the deal, before I started this rebuild I had a clicking/rubbing noise coming out of the primary side of the motor. I took the clutch basket off. It turns out that the backside of the starter ring is rubbing the shifter assembly. It actually wore the teeth down a little. So I thought maybe the clutch bearing was the problem and replaced it. Put it all back together and it still did it. I took it back apart and saw it is still rubbing.
My question is what could have got worn to make the two rub? I was thinking I could put a spacer behing the clutch to give it a little more clearance but that really isn't fixing the problem. Its just putting a band-aide on it.
I am looking for a little advice from anyone who may have delt with this already.
Ryanboeh
12-30-2016 01:16 PM
mfiumano
09-17-2006 01:07 PM
