Back Firing
Back Firing
Hey guys,
I've had my bike for a little over a week now and I've noticed that it occasionally backfires. It has occurred twice when I roll on the throttle after being stopped at a light. I've researched a bit and it seems to be coming from the carb, not the pipes. Should this be anything I should be concerned with? I'm going to Harley dealer after work, but I'm not going to mention it if I don't need to (because they'll probably try to find a way to make me buy something to fix it)
thanks in advance,
Kevin
**Edit** 2006 Sportster 883 XL
thanks in advance,
Kevin
Owning an 04 Sporty myself before go spending big bucks might want to change your CPS ( Crankcase Position Sensor ) Even if that does not solve the problem won't hurt to have a spare .. Went through 2 of them on my 04 .. If Starts and runs fine cold then gives a pop pop stuff after warmed up when stopped and seems like hard to roll off a stop ... This could very well solve and a simple change out ... Sits right in front by the Shifter and only two wires that can't confuse...
