Tire pressure?
Print is small :)
The print is small
I know 30 front and 36/40 (solo/two up) in the rear. Question is have any seen the pressure vary (lose) by as much as three pounds within a week?
Just took pressure (digital gauge reputed by auto zone to be "spot on") cold this morning in the front got a readout of 27.5.
Last Friday I took the pressure at a gas up it was 30.5 in the front?
Did I lose 3 pounds in the front tire in 4 days? Did when I took the pressure make the difference (Friday was after running 10 miles and stopping to fill up the tank; today was when I took her out of the garage)?
The suggested pressure(s) are they when the tires are cold?
The numbers given are for cold tires. You should see a 4-6 lbs increase with a fully warmed tire. Anything more than that and you pressure is too low or too high. Metzelers tend to run a lttle higher pressure than Dunlops in many applications. On my 00 I run 38 front and 40 back on my metz 880's
NoStaticAtAll (05-29-2020)
Recommended tire pressures vary by tire manufacturer and should be obtained from the manufacturers website. Their recommended pressure for a given tire will vary based on the weight of the bike model it's being mounted on.
