Tire plug
Old 06-17-2009 | 11:08 AM
stng_96's Avatar
stng_96
Default Tire plug
Has anyone ever plugged one of there tires? I recently found what looks like a nail right in the middle of the tread on my rear. Its still holding air fine now, but I dont want to keep on it with that in the tire. Can you just plug the tire like you do a car tire? or is that tire shot?
Old 06-17-2009 | 11:15 AM
ggreen2303's Avatar
ggreen2303
Same boat here. I had one in my front tire but when i pulled it was just short enough it didnt go all the way through but close. Debating on going ahead and plugging it or rolling with it.
Old 06-17-2009 | 11:16 AM
WVHogRider's Avatar
WVHogRider
Well, when you say right in the middle of the tread, is that right in the middle of the groove or the meat of the tread? Anyway, you could always have the nail removed, patch the inside of the tire and have a tube thrown in the tire. Matter of fact, I just got a screw right in the groove of my brand new rear Avon a couple days ago. The rear felt a little too cushiony, and sure enough the tire was low. I just tightened up the screw, filled it back up to proper specs for now, & been riding. Gotta remove the tire soon, and take it to have a tube thrown in it. Some people will plug'em, but most Indies/HD shops will not due to liability reasons.
Old 06-17-2009 | 11:17 AM
forever young's Avatar
forever young
You didn't mention if you had mag wheels or spoke. Spoke rims have tubes. Even if they are tubeless tires I wouldn't risk it. Bike tires go through a lot of flexing. It wouldn't take too much flexing for the belts in the tire to cut through the plug. Unlike a car, you don't have three other tires to keep you under control. I would replace the tire.
Old 06-17-2009 | 11:20 AM
vet767's Avatar
vet767
Originally Posted by WVHogRider
Well, when you say right in the middle of the tread, is that right in the middle of the groove or the meat of the tread? Anyway, you could always have the nail removed, patch the inside of the tire and have a tube thrown in the tire. Matter of fact, I just got a screw right in the groove of my brand new rear Avon a couple days ago. The rear felt a little too cushiony, and sure enough the tire was low. Gotta remove the tire now, and take it to have a tube thrown in it. Some people will plug'em, but most Indies/HD shops will not due to liability reasons.
My bet is yours are tubeless. Guess you could put a tube in. As for laced wheels, no you can not plug them. You do have a tube in those. Just like a good old fasioned bicycle tire.
Old 06-17-2009 | 11:26 AM
WVHogRider's Avatar
WVHogRider
Originally Posted by vet767
My bet is yours are tubeless. Guess you could put a tube in. As for laced wheels, no you can tot plug them. You do have a tube in those.
You are correct on all accounts. Both my front & rear are tubeless=Cast wheels. And I was only answering to his question for his rear wheel which, by looking at his sig pic, is a cast wheel on the rear with a spoked wheel up front.
Old 06-17-2009 | 11:28 AM
Sick1200's Avatar
Sick1200
I'm going to agree with WVHogRider. Patch the inside of the tire and throw a tube in there and you will be fine. Don't ever just plug it (unless its an emergency from point A to point B), you only have two tires keeping you attached to the road rightside up.
Old 06-17-2009 | 12:20 PM
Bacon_Grease's Avatar
Bacon_Grease
Yes and no.
Some folks will tell you that a properly patched tire can safely be ridden through the entire tread depth and they have plenty of examples to prove they are right.
Other folks will tell you that a tire that has been properly patched cannot be ridden safely and they have plenty of examples to prove that they are right.
You'll hear both sides of the argument here and they're both right. What should you, personally, do? You won't get a correct answer for that here. It's all about what level of risk you're willing to accept.
Personally, I plug the hole just long enough to get to a dealership for a new tire. BUT, have road hazard protection on my tires and they're replaced free of charge provided there is sufficient tread depth. (I have had three tires replaced 'free' to date under this program)
I carry, at all times, a Stop-N-Go tire plug kit and Slime mini tire inflator for just such an occassion. I have never ridden more than about 70 miles or so on a plug and I've never had an issue.
Properly patching a tire requires removing it from the rim and applying a hot patch to the inside.
Tube tires, though, are a different ball of wax.
Old 06-17-2009 | 12:23 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
I have plugged quite a few motorcycle tires although there are varied opinions on this subject. I have never had a problem as a result of doing this. i have never taken the tire off to plug it either although that is the preferred method.
__________________
Old 06-17-2009 | 12:56 PM
zetaseven's Avatar
zetaseven
I have a plug in my rear tire,been there 3 or 4 thousand miles. never had a problem.
Quick Reply: Tire plug
