Anyone using a fork brace?
I agree that the fork brace is really only noticeable when cornering the bike at higher speeds. It helps to keep the front end from having a slight wobble effect. It has no effect at all on the vibrations felt through the handlebars because of the pulses coming from the engine at Highway speeds. I use SE fork braces on all of my Sportsters except the XR1200 and my Buell XB12R Firebolt. I have seen an advertisement for a device that costs about $100.00 and it is installed inside of the handlebars and it is supposed to help reduce the handlebar vibrations but I have not used it nor do I know of anyone who has used one so I can’t say how effective it is or if it is worth the money.
this might be something you are looking for.
http://www.vibranator.com/
On a Sporty, I don't think one would make a very big difference because of the narrowness of the forks. I pushed all of my Sporty's pretty hard every so often, and I never noticed any fork flex.
On my Softail, it made a huge difference in handling (because of the Wide Glide front end). Without one, you could feel the forks flexing under hard cornering.
Put some 12.5 progressive shocks on there,really helped mine,handels like a real motorcycle now.You can also go a 160 Metzler,that and shocks will help abunch.
Front end wobble
I had alot of front end wobble when I hit about 70mph. I got the superbrace and it didn't help. I rode my Dad's Sportster and it was a big difference. So I took it to the shop and they adjusted my forks somehow and it was a HUGE difference. I should have taken it to the shop right away. I've got a 2007 883 Low.
