sportster 883 carb problem
Old 06-17-2009, 01:09 PM
vet767's Avatar
vet767
vet767 is offline
Originally Posted by ButtMan1000
I am kicking around the idea of redoing the intake gaskets again, Ugh, I hate playing with those goofy screw angles!!!
I did install early on a SE Air Cleaner Kit since I was going into the intake anyway,
I thought the revised breather hose arrangement of the SE might help, just as you mentioned, but I guess not,
Next ride will decide course of action for me, if she farts again, off with the intake,
What I did notice the last ride, she has good low speed takeoff, flattens out in the mid-range, then takes off again in the higher rpm range, this was after the idle mixture was turned out 3/4 more,
another 3/4 turn seems like a lot to me, best thing is pull your plugs and see what they tell you. With all the cr^p on bikes today, so that they meet fuel and emission standards, it is sometimes hard to tell where to start but hoses are cheap and should be changed anytime there is indication of deterioration
Old 11-28-2009, 10:04 AM
jim@jgmxt.com's Avatar
jim@jgmxt.com
jim@jgmxt.com is offline
Stage I
Default Idle mixture screw location?
does anybody have a picture of the location of the Idle mixture screw?
Thanks
Originally Posted by Bentwrench
Most people call them carb farts, where it coughs or spits when you're pulling away from a stop, if that's what you mean.
If you're talking about sort of a gargling or gagging sound at part throttle, like in second gear at a mid-range speed, that's something else.
The carbs do have a mixture screw; if it hasn't been done already, you'll need to remove the carb from the engine and extract the lead plug that is used to seal the idle mixture screw opening.
Most people say to gently seat the screw, counting the number of turns out it was just so you know where you started, and then start with 2.5 turns out. Be gentle turning that screw in because it has a delicate aluminum seat. I've found that a half turn out from wherever it was from the factory is a pretty good starting place. Then you get the engine good and warm and start turning the screw in 1/8 turn at a time until it starts the carb farting again when you accelerate from a stop, at which point you back it out an 1/8 turn and run it that way a while. A spit once in a while is no biggy. If you try to run with no spits ever, you'll be running too rich.
Carb adjustments need to be done on an engine in good working order, meaning fresh plugs, clean oil, a clean air filter and no intake or exhaust leaks. If you have a stock air filter, they are washable in warm water with a mild detergent.
Old 11-29-2009, 07:12 AM
Just Dave's Avatar
Just Dave
Just Dave is offline
Thanks
XFreebiedX already posted a good link for that pic, here it is again. http://www.harley-performance.com/ha...arburetor.html
Old 11-29-2009, 01:59 PM
ButtMan1000's Avatar
ButtMan1000
ButtMan1000 is offline
I am thinking of putting a Mikuni carb on in place of the CV,
I have had it with the farting,
Steedaflow99
12-09-2013 07:49 PM
Jim Kraft
EVO
17
05-21-2010 03:11 PM
wayne72472
03-05-2010 02:00 PM
95yj
Exhaust System Topics
03-14-2008 10:41 AM
CM1200L
08-02-2006 04:52 PM
Quick Reply: sportster 883 carb problem
