sportster 883 carb problem
Performance
Again, it really all depends on your concept of "performance". If quiet, clean, fuel efficient and responsive fits the bill, then loud, oily, souped up and tempermental doesn't really enter into the equation.
Changing to loud, open pipes of course requires rejetting. The pipes demand it. Without the exhaust mod there is no demand for extensive rejetting.
Re-jetting
You could hang a hyper-gasping air filter on an 883 Sportster, and until you opened up the exhaust to allow an actual increased flow, there still would be no need for extensive re-jetting to have a nice, clean running Sportster. But that's just arguing which of two closed valves has to be opened to allow flow through a pipe.
The bottom line is that it is the mods that create a condition that then requires extensive re-jetting.
If she took it to the dealer to have it "adjusted" I doubt they did anything to the carb, except maybe rejet it. I doubt that there is any HD dealer that will mess with mixture, or even drill out and pop the plug. EPA frowns on that big time and the dealer has to answer both to them and HD.
you can make all the idle mixture adjustments you want to on a newer 883 and it still won't run right. Extensive rejetting, probably not but you will need to change the jets to get it to run as it should. Putting a better air cleaner on it and free-er flowing pipes and rejetting for that will make it run much better and get better gas mileage since the engine isn't starving for fuel/air. An internal combustion engine is just an air pump. Any mod that makes it breath better is going to make it run more efficient and actually increase gas mileage. Mods that cram more air/fuel into the cylinders, ie cams or bigger inches will then decrease mileage because now you're forcing more fuel down its throat.
End result is that the way the bike is set up from the factory it will need to be rejetted slightly to run better. Changing either the exahaust or intake will need even richer jets and chaning both will need even more. (A better air cleaner with stock pipes WILL cause it to run leaner even though the exhaust is choking the motor.)
My 05 883L was redone with the early Sportie Needle, and I went up to a 48 Slow Jet.
After playing with the Idle Mixture Screw and Idle Speed, I got her to run beautifully.
Next ride she was carb farting all over again!!! I had to turn out the Mixture screw 3/4 more, and bump up the idle speed a hair to minimize the farting again.
This is driving me nuts,
Early on I had to replace the intake gaskets as the idle speed would go up and down like a roller coaster with no consistency in idle speed. That problem is resolved but not the erratic farting,
Sorry, rejetting is not necessary with just ac upgrade. and until you drill out the mixture plug and richen the mixture it will still run lean as set at the factory
Your right, for people who do their own wrenching, but remember if you take it to a dealer. They are not going to drill the A/F plug out. All aftermarket air cleaner manufactures suggest you jet when you install their products.
I did install early on a SE Air Cleaner Kit since I was going into the intake anyway,
I thought the revised breather hose arrangement of the SE might help, just as you mentioned, but I guess not,
Next ride will decide course of action for me, if she farts again, off with the intake,
What I did notice the last ride, she has good low speed takeoff, flattens out in the mid-range, then takes off again in the higher rpm range, this was after the idle mixture was turned out 3/4 more,
