24" drag bars on Nightster?
Hello,
I've been doing a ton of reading and am lost and confused on what size drag bars will fit. I found some 24" wide, 8.25" center, and 4.5" pullback bars and want to know if they will fit with the stock risers? I want as narrow of bars with some pullback as I can get with the stock risers. I have read that as long as the the center is as wide as possible with the drag bars then there shouldn't be a problem with the controls hitting the tank. Is this true?
Mine are 27" with the stock risers. I think 24" will put your controls into the tank. I don't have an inch...not even 1/2" of clearance.
On another note, at high speeds I feel like mine are too narrow as it is. Especially in a crosswind. If mine were a bit wider I think I would have more control.
