Update on my Iron
Sap, check out the bars in the first pic. If you look at the 90 degree top section you'll see a curved part with holes in it that supports the two bar sections. That's the gussetting. I've spoken to the owner about the need to extend the hole/dimpling up to the gussett. He said that in the future he'd either address it or the person could request the holes/dimpling go up to the gussetting. Other than that I'm more than pleased with these bars.
Edit, I got it on with the slider, It doesn't line up perfect and will work as long as your mounting bolts are long enough.....I didn't like the bottom half of the plate hanging there, thanks guys
medic, looks real nice. When you go to remove the reflectors saturate the foam double stick on it's back with Goof Off. Most hardware stores have it. Take your time and let the liquid soften the glue. Take some dental floss and triple it over and slip it in behind the reflector to cut the glue foam then use the Goof Off to clean the metal. Really soften the clue so you don't scratch the metal.
SAC make a nice bag that usually attaches to a sissy bar but could be strapped to your rack.
http://www.coolsac.com/ProductZoom.a...y_code=LUGGAGE
Licks makes a nice small bag for below the battery side cover.
http://www.lickscycles.com/catalog/s...php?page_id=61
Here's one on my 1200R;
