Question on carb jetting.
I have a 92 1200 sportser w/10,000 mile. It has dealer installed straight pipes. I got this bike last year from friend. It sat for a year. I ran 3 or 4 tanks of high test through it already. It runs better from when I got it, but it has a slight backfire through the intake. It has 2 new plugs and wires from when he got it. I pulled the plugs and the front cylinder is white and the rear one is brownish. I think the front one is running lean. Does the shop manual say what size jetts are suppossed to be in there? The dealer was supposed to of rejetted the carb. The dealer I was told are a bunch of hacks.
Where is a good place to get a jet kit or just jets? I've going to run sea foam on my next tank.
Thanks for the help,
Mike
Mike
the seafoam will probably help. The brown is what you're looking for. Your slow jet is probably a little blocked off if it sat for a year. I would run at least 92 ALWAYS in your bike. Just keep in mind that the last rpm you were running, is what you're seeing on your plugs. It was probably idle, if the seafoam doesn't fix it, there's an enricher screw, probably on the bottom of the carb, you can turn it a half turn and see if that helps.
You can get the jets from the stealer for about $6-$8 each... I think the stock jet varries from year to year but, my 04' was a 42 pilot/slow jet and I've read that you only want to go up 1 size at a time.
Worse comes to worse you can take off the carb, the jets are stamped in the top as to what size they are. check out www.harley-preformance.com they have a great article on tunning and jetting your stock cv carb.
Hope that gets you pointed in the right direction.
Jason
Jason
Phat and Blcfalc,
Thanks for the links. I guess if I get into the carb and find the enrichment plug still there the dealer probably never did anything with the carb.
jag,
I would like to get rid of the pipes but haven't any luck finding a different set. This is my first bike and it is just a stepping stone to something bigger. I really don't want to put too much money into it but I want it to run good. I think I'm going toput baffels in the pipes anyway.
jag,
Phat and Blcfalc,
jag,
jag,
