Not sure what that is, but my Step dad's 02 883 does that at times. If you have not changed spark plugs in a awhile then do so and it night help. They are only a bit over $6.00 for the pair so what do you got to loose?
check your battery cables - mine did this when i bought it. when it quit running i found the positive cable burned thru where the end crimps on to the cable where it connects to the bike, not the battery. that was 4k miles ago. no problems since.
The carb has been dynojetted and dynotuned, thanks!
yes so was mine (allegedly) ..i know mine was dyno tuned but the dealer never rejetted it..they claimed the jetting was done but i recently pulled the carb apart and found it wasnt..i still get some popping every once in a while but not too often..
