Check this Fatboy Out
Too much bolt-on stuff IMHO. The grenade blinkers might be cool by themselves, but when you have the brass knuckle levers, the light up skull horn cover (plastic??), skull taillight cover (also, probably plastic), 12 malteese crosses, every willie g skull part made, etc...
The paint is nice, but everything else makes it look cheap (while at the same time expensive as ****).
BiggDogg - try vtunnel.com
I used to use it at my last job, you go to that site (it isn't blocked by most places) and then use it as a server to go to other sites. You'll see an address bar usually pre-populated with an advertiser's site address... replace it with www.ebay.com and enter... Your on your way.
Thanks,
jason
+1 on that bro... A "mess" best describes it.
