Wish list: Any plans for your sporty
RE: Wish list: Any plans for your sporty
My wife picks her bike up in the morning, so I'll not be doing anymore add ons to my bike for a while. So far I have added auxillary lights to the front, done stage one, a sissy bar and pillow style seat, chrome oiltank & battery covers, chrome belt & sproket covers, and the light kit that makes my rear turn signals double as brake lights.
Her list so far includes pipes, auxillary lights and the same tail light kid I used on mine.
Skullcrusher.....the bars are standard 9 inch rise bars for a Dyna Wideglide.....cost me about $44....but you need to change ALL the cables and extend the wiring....also moved the signals....thats where the money came in since I went with stainless throttle (both) and brake and clutch cables. I like the look and it is extremely comfortable to ride.
ORIGINAL: spikehyre
That is the same thing I did, but I did leave the turn singals on the bars.
I finished putting my bike together over the winter. All I do now is ride.
Additions / Changes / Bling:
Screaming Eagle II Slash Down Mufflers, Arlen Ness Big Sucker Stage I Air Cleaner Kit, Carb Rejet, Oval Air Cleaner Cover With "Live To Ride" Insert, Leather Badlander Seat, Le Pera Daytona Sport LT Vinyl Seat, Detachable Seat Hardware Kit, Detachable Mini Sissy Bar, Tapered Luggage Rack, Lower Front Slider Kit, Clutch Cable Connector Cover, Tappet Block Cover Kit, Enrichner ****, Horn Bracket, Headbolt Bridge Kit, Oil Temp Dip Stick, Rear Brake Reservoir Cover, Tail Light Collar, Coil Cover Kit, Voltage Regulator Cover, Ignition Switch Cover, Front Axle Nut Cover Kit, Wheel Spacers, Upper Belt Guard, Lower Belt Guard, Swingarm, Pivot Bolt Covers, Rear Axle Cover, Sprocket Cover Kit, Upper Shock Covers, Master Cylinder Cover, Brake Caliper Inserts, Rear Brake Rod, Valve Stem Caps, Switch Covers, Hand Grips, Foot Pegs, Shifter Peg, Hand Levers, Slotted Stem Mirrors, Billet Fuel Cap (Cross), Skull Fuel Cap Medallion, Stainless Bar and Shield Shift Linkage, Headlamp Visor Style Trim Ring, Bullet Style Turn Signal Visor Kit, Lay Back License Plate Mounting Kit, Bolt / Nut Covers, Derby Cover, Timer Cover, Clutch Ferrule and Banjo Bolt Cover Kit, Stainless Clock, Stainless Temperature Gauge, Small Fork Bag, Trickle Charge Pigtail, Front Spoiler, Fuel Tank Trim Panel Kit, HD Skull Ignition Key, Vanity Plate (USAF).
Removed:
Passenger strap and reflectors.
Ain't done nothin' this 'un is bone stock Huh except
Relocated Front(kit from a Dyna) and Rear(Light Bar from Softail Touring Model) turn Signals,
Pillow Top Touring Seat
Short Sissy Bar with Custom Pad
Kuryakin Pegs with Heel Rest
Sporster Pull Back Bars
Custom Graphics on Tank, Front and Rear Fenders
Chrome Engine and Tranny Covers,
Ride to Live Medallions for Air Cleaner, Gas Cap, Sissy Bar, Derby, Primary, Brake Calipers
Stainless Braided Front Brake Line
Chrome Rear Master Cylinder Cover,
Chrome Tappet Block Covers
Chrome Spark Plug Bridge
Chrome Upper Belt Guard
Chrome Front Sprocket Cover
Chrome Choke Bracket & ****
Chrome Ingnition Switch Cover
Chrome Headlight & Front Turn Signal Nacelles
Screamin Eagle Slash Down Slip On's
Various and many Chrome Bolts and Bolt head Covers,
Front and Rear Chrome Axle Nut Covers
Oil Temp Gauge Dip Stick
Windshield, Custom One Off, made it myself
I would like to replace all the lines with braided lines. Run the wires inside the handlebars. Maybe a windshield to use on long trips. Relocate the front turn signals, maybe also the back signals. Maybe work on adding chrome to the front end. Luggage rack. Heck I am sure I will come up with more once I get these done.
