I have the solution to the Side Cover Problem
Old 05-18-2009, 08:59 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
You don't have to zip tie it to the frame. Drill a hole in the plastic clip where the oval hole in the metal side cover sits when the cover is mounted. Then, stick a zip tie down through the two holes (no need to wrap the tie around any thing). The head of the zip tie will keep it from sliding through. I can get to it to pull it out and replace it without removing the seat and I've used the same zip tie for a few years.
Beancount1
01-03-2012 05:02 PM
chrism84
11-24-2006 12:02 PM
chrism84
11-23-2006 05:48 PM
Quick Reply: I have the solution to the Side Cover Problem
