Polished Stainless Bolt or chrome
2004-2009 Harley Sportster Polished Stainless Bolt Kit
I was thinking of getting a set but had a few ?'s
1. I'm a pipe fitter so i know that stainless and heat don't mix very well im my shop heat will screw up threds fast. Has any one had this problem or did any resarch on this.
2. Would the best way to change all the bolts be to remove one at a time and replace and retorque each one as i go.
3. Chrome bolts do thay last and are thay hard to maintain. I have heard thay crack and chip easy.
4. I have the stock bolts on my 883n and thay are starting to tarnish thats why im thinking of changing my bolts out.
I'v thought about the toppers but thought thay would fall off, and have to replace one every few 1000 miles or so.
As far as the ss bolts did thay break the first time you tryed to take them off or during opperation I would think ss bolts over time would get brittle with the constant heating and coling. SS expands a lot more than carbon and shrinks more with heating.
Aluminum and regular carbon steel don't get along real well either , everytime I pull a bolt out its oxidized pretty good . SS or regular steel , its best to use a anti-seize or a light grease , not supposed to torque dry threads anyway !
