Polished Stainless Bolt or chrome
there is a chemical reaction that occurs between aluminum and steel. I had not considered this fact before. Maybe a machinist or engineer can tell us why and if it can be prevented.
Received 1,297 Likes
I've used stainless (304, 316, 410; passivated and active) for over 35 years attaching aluminum primaries, cam covers, tranny covers, rocker boxes, etc. I have never broken a stainless screw in these installations, and have never had a problem removing them. While I have occasionally put them in dry, or used motor oil to lube the threads, I normally use blue Loc-Tite, or a similar product, and usually torque them to the factory spec, although I'll admit I use my "calibrated" fingers nearly as often.
On my Shovel I used stainless cap screws, nuts, and lock washers to attach the exhaust to the aluminum heads. In this case I used a nickel-based anti-seize on the threads. Never stripped a head, or had the exhaust loosen.
To sum it up - Use the correct thread locking compound, or anti-seize compound, and torque to specifications. Then ride the thing!
Not all chrome bolts are created equal.Before the chroming process the bolts should be baked for a certain time at a certain temp.If not they're weakened drastically by chroming.Go with stainless but like someone else suggested use anti-seize when threading into aluminun to prevent galling.
I have a 08 1200C, a year ago I bought all the polished SS bolts for my bike. Have not had a problem with them, even after a year they look great. Pay attention to the torque specs and I coated them with anti-seize and did the torque that come with them, yes I did one at a time. Some of them have been in and out several times. No problems yet. If you feel they are getting snug on the way in, take it out and run a tap in the hole, then blow it out with canned air. I checked each hole first with a "dry" bolt. Worked great. Hope this helped. Ride safe.
