2009 sportster 1200 custom
Old 05-13-2009, 06:53 PM
KAST's Avatar
KAST
KAST is offline
Stage III
Default 2009 sportster 1200 custom
Is it normal for this bike to get really hot even if was riding for just a half a mile?
Old 05-15-2009, 02:31 AM
Teek's Avatar
Teek
Teek is offline
It takes about 3 or 4 miles for a bike to get to operating temperature, depending on the ambient outdoor temperature, engine speed, etc. Define "hot"? I have an oil temperature dipstick on my '07 and it runs between 150 and 210 degrees, depending on if it's really cold outside or whether it's 110 on the pavement. If I ride in shorts, my bare legs can get pretty hot real quick. I also run synthetic oil, which drops the oil temp around 10 degrees or so. It's an air cooled engine, so the bike needs to be moving. Being stuck in traffic on a 100+ degree day will heat the engine up quite a bit, possibly to the point of overheat.
But to directly answer your question about engine heat at 1/2 mile...are you going from a cold start to highway speeds in that 1/2 mile? Or is it "normal" 35 mph city streets?
Teek
Old 05-15-2009, 06:16 AM
Zimbob's Avatar
Zimbob
Zimbob is offline
Like Teek said, Define hot. What's hot to one person is just warm to another.
Old 05-15-2009, 07:40 AM
killer scott's Avatar
killer scott
killer scott is offline
Probably... Depending on what you mean. I rode mine around the block when I first got it. Then the girl jumped on and burnt her leg on the pipe... Those get hot fast.
Old 05-16-2009, 12:01 AM
kfish1200's Avatar
kfish1200
kfish1200 is offline
1st Gear
Default Hot
if i am ridin for only only 4 or 5 miles i can wear shorts with all ok, so something not normal.
Old 05-16-2009, 02:30 AM
sajackson's Avatar
sajackson
sajackson is offline
Pipes get hot just going around the block so I suppose it depends on what exactly you are talking about.
Old 05-16-2009, 07:30 AM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
air cooled motor not your yuppy water cooled short ridin bike
Old 05-18-2009, 07:17 PM
KAST's Avatar
KAST
KAST is offline
Stage III
Thumbs up 2009 sportster 1200 custom" by KAST
All you guys have helped me a great deal. Thanks a lot. I basically received the same response from the harley dealership. Its an air cooled engine and that's expected.
It's the nature of the "b e a s t".
Thanks again for all the info.....
Old 05-18-2009, 07:19 PM
killer scott
Yep. Throw on some jeans and ride!
Old 05-18-2009, 10:11 PM
twitchy's Avatar
twitchy
twitchy is offline
I would get a dipstick temp gauge. Cheap peace of mind. I thought mine was running hot too but come to find out.....it's not.
Quick Reply: 2009 sportster 1200 custom
