Louder with Mufflers Only
RE: Louder with Mufflers Only
You can usually add Cycle Shack Slip-ons or SE II Slip-ons without the need to swap the air cleaner or change jets. What you'll get is more of the Harley sound, but the performance increase will come only when you change the AC and re-jet in conjunction with the free-flow slip-ons.
Thumper26
Thumper26
When I changed my '99 to the cycle shack slip-ons, it started running on the lean side. Not super lean, but lean enough that I was concerned about making the trips I make when the weather really heats up this summer, so I went ahead and did the carb mods. Better safe than sorry I figured.
I guess each bike is different, but I would definetly read the plugs and monitor what the mixture is doing if you just change the mufflers.
