Need Help
Need Help
Just purchased a 2008 sportster XL1200C and I want to change the front tire and wheel from the tall skinny 21" to a fatter 16" or 17" know I will have to change the tripple trees out for wider ones. Is there a set of tripple trees on any other Harley that will fit the sportster frame and the 39mm tubes that will make the job easer also the front axle is 1" any sugestions on a front wheel and disc brake setup
Thanks Walker
Thanks Walker
