Proffesional Nightster advice needed.
dude this is not a bolt on for your 09 N. first you do not have carbs, you have fuel injection, you had better talk to your dealer, at very least you will need to remap the computer or buy a fuel pak or power commander. and make sure it bolts up to the intake and not a carb
The velocity stack will wear out your engine in short order as it allows ever speck of dirt to go through your engine and a screen will only keep out low flying birds and the other thing is a a tachometer that looks cool but is mounted in a really stupid place, who in the world would want to be looking behind there leg all the time to read a tach, a tach is suppose to be in your face to use it properly.
while this is true for most stacks it does not aply to all. mine has a filter so it works just like a regular breather....
that being said it does suck in the rain, i recently got a soc but have not had to test it out yet...
Received 1,297 Likes
It's an engineering vs looks trade-off. Nothing wrong with balancing that equation however you want, but it's best to know what your final equation equals.
charlietheharley
04-29-2010 04:51 AM
