Brake light problem
04-19-2009, 06:30 PM
Brake light problem
Hi Guys,
Again I need your xpertise opinion, My brake light is not working pressing the brake level or the brake pedal, I checked the Buld, fuse, the housing swicht,what else can it be. I have a `07 1200C, thanks in advance.
04-19-2009, 06:35 PM
That pretty well just leaves the hydraulically actuated switch.
Use your voltage tester and check for juice when you are holding the brake down
04-19-2009, 06:37 PM
Yes, I check the service manual and that is the final stop, also said that I`ll need to remove the oil brake level to get there!! there any other way.
04-19-2009, 06:39 PM
check for voltage before you pull it apart,,maybe a broken wire,,and for good measure try a new bulb,,sometime they can fool you.
04-19-2009, 06:53 PM
Lets try that first, the new bulb, have to wait until tomorrow, thanks.
04-19-2009, 06:56 PM
good luck
04-22-2009, 10:35 AM
Done,
New light bulb, problem some !!
drsnipes
12-03-2023 01:18 PM
blackbike
EVO
12-17-2014 06:30 PM
mattyj724
06-03-2013 12:49 PM
rsnky62
05-02-2010 10:44 PM
Bradt
06-08-2005 12:35 PM
