Ape hangers grip on risers
Old 04-18-2009 | 08:23 PM
congo_usmc's Avatar
congo_usmc
Default Ape hangers grip on risers
hey, I installed my apes a couple months ago they werent knurled and didnt hold tight in the risers so I wrapped a piece of duct tape around the bar and they held very nicely. unfortunately they are coming loose. Anyone know a good alternative to duct tape? thanks for any help
Old 04-18-2009 | 08:34 PM
vegasrock's Avatar
vegasrock
i've heard a shim made from an aluminum can works good
Old 04-18-2009 | 08:36 PM
anubisss's Avatar
anubisss
Or emory cloth.
Old 04-19-2009 | 07:47 AM
capttawes's Avatar
capttawes
Take em off and sand them and the riser contact points and take a file and scrore some criss-cross marks on the bars and they should hold (also torque the clamp to the proper 14-18 foot pounds).
Old 04-19-2009 | 10:15 AM
Razorback Rob's Avatar
Razorback Rob
Aluminum can doesnt work. I have the same trouble. I havent tried the sanding though. I'll do that this week. Thakns for the info.
Old 04-19-2009 | 10:29 AM
notfried's Avatar
notfried
like stated before,just grind yer own
Old 04-20-2009 | 04:17 PM
jag1886's Avatar
jag1886
I've used a center punch before and made several rows of indensions around the bar and also make certian your riser clamp is tighten evenly, there should be a visible gap on both sides of the clamp.
Old 04-20-2009 | 09:44 PM
congo_usmc's Avatar
congo_usmc
well i broke out the dremmel and tried sanding and I even carved a waffle pattern into both the bars and the riser. no luck still loose. so i just went back to the good old duct tape. this just might become my 3 month routine. hopefully it will hold better and last longer this time around
Old 04-20-2009 | 10:19 PM
pococj's Avatar
pococj
+1 on the dimples. Used to use this trick on electric motor bearing races to keep a motor in service 'til we hit port or the tender. You can also slightly deform the bar where it contacts the riser clamp area. Whack it judiciously with a ball pein hammer to make it slightly oval shaped. That allows the clamps to squeeze-hold it, sorta like a square peg in a round hole. Gotta be careful not to get it too far out or you can strip the risers/riser bolts tightening it back down.
Old 04-20-2009 | 10:23 PM
old skool1983's Avatar
old skool1983
i just recently had this same issue, tried the duct tape...no good, tried the beer can shims....no good, i went back to the tried and true way i did it a couple a years ago... i pulled the risers compleatly off the bike, borrowed my buds welder and threw some tac's into the tops and bottoms of the risers, this made an abrassive surface, didn't mess up my chrome, was off the bike so i didn't have to worry about wires or the gas tank or paint, and its workin just as good as it always has
Quick Reply: Ape hangers grip on risers
