Need a Professional At A Nightster
I wanted to change out my exhaust and I was told I need a fuel pack. Is that true? Do I need anything else? Also if someone could tell me what size my factory handle bars that would be great. I keep getting the run around at the dealership. If anyone could also let me know what they think about Vance and Hines Short pipes. Thanks for the help. Josh
If you are running with the stock air cleaner, you can just change the pipes and that is all you need. If you change to a higher flow air cleaner, then you will need to either get it remapped or add on a fuel management system like the PCIII or the fuel pack because it will run way too lean. Seems like everyone has the V&H SS pipes... I, for one, do not.
Your bars are 1 inch in diameter if that is what you need to know... Most metrics are 7/8 inch.
Thats B.S. I have V&H short shots and a high flow air cleaner. No fuel pack or computer mapping. Mine runs like a raped ape! These bikes come from the factory running a little rich. It seems that when I took the baffles out of my pipes, and added the air cleaner that it evened things out. But, yours may be different. It won't hurt anything to find out. Also, when you said size, do you mean width or diameter?
eh? Survey says................lean from the factory due to EPA regulations...
Unlike a car, the O2 sensor won't adjust, because the bike is running open loop from the ECM tables most of the time, and it's assuming how much air came in for a given RPM and trottle setting.
Pipes have a minor effect on getting more air into the cylinders, but a free breathing air cleaner has a major effect.
BTW gpsjr10, metric would be 22mm (almost, but not quite 7/8 inch). We're the only remaining civilized country, as we still resist measuring small things in units approximating "thousandths of a yard".
If you look on E-bay for bars, most of the metric bars are listed on there as 7/8 in... That was my point...
And there's nothing like the sound of your motor doing a meltdown.
If your motor is running fine, your high flow A/C ain't very high flowing.
