Starting to miss my Honda.
I was more looking for some input on what to troubleshoot as I seem to have exhausted all the main components. My '82 a is genuine Harley, not an AMF bike. And, yes there is gas in the tank and the petcock is in the proper position.
It starts and runs fine, but when I ride it for an extended time 5min or more, it just quits (no spark), it seems to run longer without the point cover on. Also, it may be unrelated, but the Tach now bounces around like crazy too.
-Thanks
-Thanks
Might be relevant
Tachs (at least on older cars) were connected to the ignition coil. You may have a coil issue if all other electricals are working. After it quits, check for spark. Sometimes a coil going bad will work initially but overheat and stop suddenly. Wheneverything cools down it works again. As for the bolts, can we get a picture? maybe we could advise on the correct tool if we saw the hardware.
Received 1,297 Likes
Bolt problem - Those are just "make-prettys" - covers that should pop or pry off.
Electrical problems on a 20+ year old bike? That's hard to believe!
Sounds like something crapping after it heats up. I take it you have no wiring diagram? You really need to cop a service manual w/diagrams. Then start eliminating all the "points of interest" from the battery to the spark plugs, one "point" at a time. You can run temporary wire to bypass the ignition switch, the ignition circuit breaker, the kill switch, etc. Even the wiring is suspect at this point.
How old was the reliable Honda, and how many were exactly like it? My friend at work has an 81/82 (mixed custom) Sporty hardtail. It also has lots of "character". If you want reliable you have to get something a little newer than 26 years old, or break it down to the frame and re-build it to like new condition. Buy a 26 year old Honda if you can find one that still runs. (not trying to be rude just tying to make the point)
