GPS Mount ?
www.rammount.com has the mount that most use. Look up the parts that you need then check on amazon.com to see if you can get them cheeper. I got mine 50% off. I use the bar clamp with the short extension and a ball mount at the top. You can see from the site what I mean. I mounted a Garmin Nuvi 350 on my 06 and 09 Ultras. Work great. There are some small chrome mounts out there. Maybe others know about them. I have used the ram mounts and they work great.
I mounted a Garmin Quest on my lowrider using the ecaddy that mounts on the controls Thinking of getting the ultra tilt
http://www.leadermotorcycle.com/PROD/ED-HD.html
custom made by my brother and myself... used a mirror arm, piece of alum that i used the mill to take out, and 2 support brackets that are powder coated to match the frame and then threaded to hold in the GPS... i use a TOM TOM 1xl... works as a speedo and GPS on the scoot...
On my Harley i have a braket that i made to run attach it to the wind shield... that way i can plug it in for long trips:
![](http://i41.tinypic.com/2mmi7fo.jpg)
![](http://i43.tinypic.com/106zw9c.jpg)
![](http://i44.tinypic.com/2mdp4qu.jpg)
![](http://i41.tinypic.com/11bneom.jpg)
i carry the ram mounts at great prices and you will receive 10% off with coupon code HF10 at checkout.
