DYING from Vibration
I put on these alloy art bushings and nostaga grips. Not too bad now.
http://www.dragspecialties.com/fatbo...?q=alloy%20art
Also, check your motor mounts and other hardware just to make sure its not something else. Easy for old solid mounts to shake things loose.
did you check out the ricor web site?Some peolpe have been installing these.
http://www.vibranator.com/
Your vibration at Highway speeds is normal and probably caused by the high RPMs that you have to do to keep up at those speeds. The stock 883 Sportsters have a 27 Tooth Transmission Drive Pulley on them and the stock 1200s have a 29 Tooth Transmission Drive Pulley on them. For about $150.00 you can buy a 29 Tooth or even a 30 Tooth Transmission Drive Pulley from Harley and after it is installed on your bike your RPMs will drop so that at about 80 MPH or so you are only doing about 4,000 RPMs or so and that should help out a little bit with the vibrations. I also put on those older fatty squishier foot pegs too and boy are they nice. You can try to find them at smaller independent motorcycle shops that do work on HDs as many people throw them away and put on different foot pegs for the looks! I picked up about 6 sets of these types of foot pegs for free and all I did was to ask the local shop about them and they gave them to me because nobody wanted them. Go figure? Anyway, I hope this information addresses your issues and ride safe.
