sundowner
no problems with mine.
be sure the seat is bolted down tight.
The Sundowner did move me up a little bit closer to the bars, but I don't move when riding. Try leaning back a little in the seat when riding a more 'touring' position.
If you still have problems, you might want to try another seat.
Yes, you slide the tongue into the connection at the base of the fuel tank, but then you need to push down on the seat, and slide it back. There is a post on the fender that is a keyhole type connection for the middle part of the seat. It should NOT wiggle. It can be a bit tricky to make sure the post connects into the keyhole fitting.
I'll have to recheck it, I only went on a short ride to test it out, its a bit cold and windy here. And the seat doesn't wiggle or move while I ride it, only when I move it while its sitting. I noticed the wiggle after installation, I checked to make sure it was firm and it moves a bit, but I guess its the super thick foam moving? Good to hear its normal. The sliding part is the most annoying though, I guess I am not used to being closer to the tank. I'll have to give it some longer rides to see how I feel.
