Powder coat OVER ceramic coat? (heat shields)
I have a few scratches on the bottom edge of my heat shields and my painter didn't fill them before he ceramic coated them again. The shields are fully covered, but I don't want these deep scratches showing even though you can only see them from up close. Is there a way to better prep them for ceramic coat (apparently body filler won't work), or should I prep them as you would any other body work and powder coat them and will the powder coat hold up in the heat?
Thanks!
D
Thanks!
D
Guest
Posts: n/a
You would have to lightly tig weld over the scratches and grind them out and then i would suggest having them re-ceramic coated.A hi heat powder might last a while but i have had alot of bad experiences with using it on heat sheilds,its got to the point that a will not warrenty it on heat sheilds.Don`t get me wrong powder coating has its place like on a frame or swing arm,but not a place where lets say your leg is going to rubbing up next to it all the time.Jb weld is not liquid metal,it requires a hardner to make it become hard and will out gas during the curing process and will leave you with a bigger mess than your scratches.
