Flipping the mirrors over on my Iron
Old 03-16-2009 | 10:42 AM
bolillo57's Avatar
bolillo57
Thumbs up Flipping the mirrors over on my Iron
Basically all you do is take the mirrors off and swap them - left to right, right to left, there is a bolt that you take off and just mount it back on top.
When you take off the bolts there are little rubber caps on the end of the mirror stalk that covers the threads. Watch for those - very easy to drop and loose. I dropped one and it took about half hour to find in parking lot.
As far as function they work great, now instead of looking at your arm the point of view is basically at your hips so you can definitely see whats behind you.
When you go to tighten the mirrors I suggest turning the bars to make sure the mirrors don't hit the tank. The turn signals look as if they will get in the way but they are mounted on a swivel joint? so you can just push them over to make room.
Also I had to thread the right mirror between the throttle cables to avoid binding anything.
Try the swap, very easy and works great. Just took a little getting used to looking lower to see behind you and it really cleans up the top of the bike. Sorry for rambling on about this but you'll see what I mean.
Pic #4 shows how I ran the stalk between the throttle cables.
Pics 8-10 are the little cap I mentioned, also I'm going to get some black paint or nail polish and color the bolt to hide it since it's shiny.
Last pic is of the forward controls I had installed when I picked mine up.
Next in plans after the daughters wedding are new footpegs, hand grips - the black tribal design.
NHRS 1250cc conversion will definitely be coming later also.
Also tossing around the idea of some sort of pinstriping in orange/silver
Attached Thumbnails Flipping the mirrors over on my Iron-swapped-mirrors-002.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-003.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-004.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-005.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-001.jpg
Pete Robertson (11-01-2019)
Old 03-16-2009 | 10:44 AM
anubisss's Avatar
anubisss
Won't they hit the tank if you turn your bars all the way left or right?
Old 03-16-2009 | 10:45 AM
bolillo57's Avatar
bolillo57
Here are the rest of the pics
Attached Thumbnails Flipping the mirrors over on my Iron-swapped-mirrors-006.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-007.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-008.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-010.jpg   Flipping the mirrors over on my Iron-swapped-mirrors-011.jpg
Old 03-16-2009 | 10:47 AM
bolillo57's Avatar
bolillo57
What I did was turn the bars, set the clearance, then tighten the nut.
Works fine and don't touch at all.
You can see the clearance in the very first pic.
Old 03-16-2009 | 10:51 AM
anubisss's Avatar
anubisss
Obviously I wasn't paying much attention. Cool.
Old 03-16-2009 | 11:04 AM
joebotics's Avatar
joebotics
Bollilo... thanks for the detailed pics and explanation... running back home to try it on my Iron... :-)
Old 03-16-2009 | 11:55 AM
HOTLAP's Avatar
HOTLAP
I did the same and it's amazing how much more you can see without your arms in the way.
Old 03-16-2009 | 03:54 PM
Bacon_Grease's Avatar
Bacon_Grease
I was planning on ordering some longer stem mirrors, but I think I'll give this a shot first. Everytime I check my mirrors, it looks like I'm about to get run over my a giant elbow!!!!
Old 03-16-2009 | 04:11 PM
BadNight09's Avatar
BadNight09
Any idea if this will work on an 09 nighster?
Old 03-16-2009 | 04:40 PM
TheLaw's Avatar
TheLaw
Yep.
https://www.hdforums.com/forum/membe...ure14849-a.jpg
https://www.hdforums.com/forum/membe...ure14847-a.jpg
The LAW
Quick Reply: Flipping the mirrors over on my Iron
