Fuel enrichment knob ( choke related )
Fuel enrichment **** ( choke related )
Yep that's what the dealer called it "choke enrichment ****"...........
Anyways, when I start the 1999 883 Sportster I pull out the "choke" and it wants to go back in after a 30 seconds or so.
Temporarily I have made a little clip (closepin like) that goes on around the stem and I pull it off myself
after it warms up while I am riding.
Is there anyway I can get the choke to stay pulled out until I push it in?
RE: Fuel enrichment **** ( choke related )
There is a plastic tensioner nut on the enricher **** stem. Turn slightly, I believe clockwise and the **** will stay out until you push it back in. If that doesn't work, then try counterclockwise. If that doesn't work, you may have a slight problem with the enricher cable, but I seriously doubt it.
