Pipedreamz Insomniacz
Old 03-12-2009, 08:52 AM
schultzy60's Avatar
schultzy60
schultzy60 is offline
Originally Posted by txoval
I run them without the bracket...if you tighten the header bolts and bolt the pipes together at the bracket they are't going anywhere...
what did you use to bolt the pipes together? Did you "HAVE" to put forwards on with those or did you already have forwards?
Old 03-12-2009, 01:48 PM
Nixon1200's Avatar
Nixon1200
Nixon1200 is offline
did anybody else seem to have trouble putting in the baffles on their pipe dreamz pipes? mine would thread in fine but they would rattle around easily. kind of a weird set-up but i eventually was able to thread it to stay tight but i think what i really did was cross thread the bolt onto the bracket. it hasn't moved and i haven't heard it rattle since so whatever.
Old 03-12-2009, 03:56 PM
txoval's Avatar
txoval
txoval is offline
The pipes have tabs on them that you bolt them together with, the bracket attaches to the same tabs.
I already had forward controls
Old 03-16-2009, 08:29 AM
schultzy60's Avatar
schultzy60
Allright, so I got the pipes on, got the breather on, and installed the power commander. Now when i run it, the fuel pump light comes on. It goes off when I idle in nuetral. Anybody got any ideas? I am thinking I need to fine tune the PC. It is a PC III EX if anyone has any hints to programming that thing. The only map that I could find that was close was PipeDreamz Wet Dreams Pipes with the Screaming Eagle Breather. Let me know if anyone can help.
2006FLST
11-11-2010 01:54 AM
Irishwoodchuck
05-15-2010 10:30 PM
nlando
05-03-2009 02:55 PM
Benita
09-11-2008 08:24 AM
drumer66
03-21-2008 06:53 PM
Quick Reply: Pipedreamz Insomniacz
