**How Many Iron 883 Owners Out There?**
#2501
#2502
#2503
Yep. Took about 5 weeks to make to the options I wanted. Superrrrrr squishy comfy on my tush. Basically like a "48" seat but not as big. Tell them you want the 82 - 03 version for the 04+ and he will make it.
#2504
http://www.sicksaddles.com/store.php...74&id=12053043
Fits no problem on a 2013? Did you chose all the upgrades too ... thinking of going with the grey stitching, no idea if it is really noticeable though.
I wonder if they diamond pleated pillion pad like the 48's pillion to go with that seat .... that would be sweet!
#2505
Thanks, it's this one right?
I chose memory foam, full leather, grey colored stitching, diamond pleated. The leather is really nice soft quality. Like high end Mercedes. It should fit the pad, it mounts in the same spot as the 48
#2508
Some xied leads wouldn't do any harm for you ride
#2509
When I fitted short shots I went with the fuel pak and V&S air cleaner. Bike had aquite a flat spot in second going up to peak RPM, bad flat spot, it actually cut out. The short shots with regular baffles are VERY loud so I went and fitted quiet baffles. Well the flat spot cutting out problem is gone and my hearing will be preserved a bit longer. Try the short shots as is but pretty sure you will need some sort of fuel enrichment if you have in the loud open baffles.
#2510
Just bought my first Harley. 2013 Iron Candy Orange. I already flipped the mirrors and went with buckshot heat sheats on the pipes. I will try to get a pic up here soon. I am looking for a solo seat that will puch me back a little further than the stock one though. I like that sicksaddles seat... how is the fit compared to stock.
