Bike is not starting???
Old 03-04-2009, 02:32 PM
Threehouse1200N's Avatar
Threehouse1200N
Threehouse1200N is offline
Default Bike is not starting???
I just went out to start the bike up and she won't fire. All the lights are coming on normal power as usual it just won't start. Not sure if maybe its too cold out or what. Any info or tips here would help. Thanks
Old 03-04-2009, 02:37 PM
drivel's Avatar
drivel
drivel is offline
Kind of a duh answer... but did you check the spark plugs? Plus... ya know.. is there gas in the thing?
Old 03-04-2009, 02:39 PM
Threehouse1200N
Checked them....its sounding very well when I go to start it most of the time not even rolling over at all
Old 03-04-2009, 03:02 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
It's just too damn cold outside..... Mine wouldn't turn over today either.... just wait till it gets warmer or heat your garage....
Old 03-04-2009, 03:10 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
Check your relays,there is issues there
Old 03-04-2009, 03:20 PM
Threehouse1200N
Hopefully the cold is the problem I'm trying to warm it up rite now b/c I gotta make sure it runs. If not then I'm F'ed!
Old 03-04-2009, 03:49 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
It'll start when it's warmed up a bit.... Make sure you keep a tender on the battery.
Old 03-04-2009, 03:55 PM
Bryan53's Avatar
Bryan53
Bryan53 is offline
Wait till the warmer weather hits. Don't just fire it up to hear it either. You need to let that thing get fully warmed up starting it and letting it sit there is bad. Start it let it warm up for about 5 minutes then go for a 30 minute ride. In the winter if I can't do that then it will sit till I can.
Old 03-04-2009, 04:15 PM
Threehouse1200N
Thanks all I got it warmed up and she fired. I took it out for about 30mins and it ran fine a little cold out but worth it!
Old 03-04-2009, 05:18 PM
bmxatv's Avatar
bmxatv
bmxatv is offline
Now put it on a battery tender!
Quick Reply: Bike is not starting???
