Enricher Sticking????
It is made of plastic and will break!!! Do not lubrictae this cable; it operates on friction!!! The back nut is for tightening and the front for adjusting tension. Loosen back hex nut so cable is free from mount. Loosen the plastic retainer: **** should slide in out easily. If not, may want to take it off and out of the carb, inspect it, clean it, and put back in. About an hour work. How to is in the service manual. If okay, adjust the plastic knurled retainer until it will just hold the **** fully out. Replace cable in mount with flats lined up and tighten (easy with the minkey grip) the hex. **** should work fine now.
