how do you like it? does that back rest really work well? thanks in advance for the help...
I've had one for a couple years (got it through www.easternperformance.com for $129). Really nice bag with ample storage for its size. My wife and I use it for daytripping often and I use it solo when I need to carry stuff. It makes a great backrest when flipped around and strapped to your sissybar. A couple things I will note however that the back pad that just sticks on with velcro gets in the way and pushes you fwd. so I don't use it and secondly the way they suggest just strapping it to the seat with the pad and straps that are included is just ridiculous. With stuff in the bag or using it as a backrest it will twist and hang off the side of the bike and will slide all over even when strapped tight. I only fasten mine to the backrest when in solo mode. The large compartment will hold a FF helmet so its roomy. We can usually load it up with sweats, jackets etc. as well as tools,, snacks water and whatever in the side compartments and the top zipper section is good for rain gear, also comes with a waterproof cover.
