Coil Question...
Not so unless you have an older Sporty. Current models (2000 up ?) use a single fire ignition. Looking at the coil from the left side of the bike, the closest coil connector gets connected to the front cylinder.
Thanks for the help guys... I just threw enough back together on my bike and cHarley is indeed correct.
After switching around the plug wires and cranking the bike over she did not start. I did manage to shoot a few 2-3 foot flames out of my short shots in the process
Time to rewire the coil plug to see if I can run the plug wires the way I want to.
Greg
Greg
OK, I found which wires to swap in the coil plug:
Just swap the blue+yellow stripe wire with the yellow+blue stripe - they should be right beside each other. (Just a FYI - The other two wires are yellow+green stripe and look very similar to the yellow+blue.)
You need to remove the pink bit of plastic at the end of the plug first, it was difficult but keep working at it carefully. Then just push the black plastic clip that holds each wire and swap them out.
I just installed some red SE spark plug wires from the Rocker and it looks pretty sweet.
I know this is an old thread but the info would be good to keep here I think...
Woods Glen
10-23-2010 06:52 PM
