Brake Line
Brake Line
2003 XL 1200 C. I've been thinking about putting on some apes and it looks like the clutch and throttle cables will be long enough. The front brake line is "iffy" tho'. My question is - in order to gain an inch or two, can I bend the "L" shaped metal brake line with no ill effects?
If u dont have apes go home.
I probably wouldnt just bend that hard tubing. i put apes on all i changed was the front brake line. With a little reworking of the wiring everything else will fit but just barely with mini apes taller than those wire extensions will be needed. Find a set cables from a street bob that came with apes its a perfect fit.
Street bob
Bending
No problem.. thanks anyway. After more careful measuring, it's just not going to be enough using existing cables. I don't think I know of anyone who has done this and was satisfied with the results.
SGTGunner
10-31-2010 05:34 PM
