Rigid Struts + solo seat...how many of ya?
have done this combo?
i'm waiting to use my buddy's garage facilities to cut my rear fender and then add the solo seat.
but i already have Licks' Rigid struts on, and it's a pretty hard ride.
i'd like to take it to Sturgis this year, give my heritage a break,
but i worry about the harness of the ride.
i could just get some blacked out short shocks for the rear, but i'm trying to keep it all retro and stuff.
any tips or info from you guys that have done it all?
dan
dan
I rode with struts for a WHILE.Bates style solo seat with NO springs.Yeah it's a rough ride but for me it was what I was used to and I enjoyed it.I like riding cycles that are challenging.Mid controls help.You can stand up and get off the seat some.I had no problem doing a few hundred miles on this bike.........thats where the 2.2 peanut helps.....frequent stops.After a whole day you kinda feel like you got the **** kicked out you .........good times!!!!! A whole different ride than a real rigid
Seroiusly, if you're gonna do alot of highway riding the struts aren't bad at all........as long as the roads are decent.You gotta be more aware of whats comming up in front of you.You also gotta watch your hard turns cause the rear will will tend to skip if if it's bumpy enough.Just take 'em slower........you'll get the feel
I've since went back to shocks.........covered shocks from an old Shovel.........I think ,
and they're not a whole lot better but I do get a little travel which helps on real rough spots.The only reason I switched back is 'cause I do alot more city riding now and the potholes and train tracks were killing me...... and too much **** started to fall off.
Might just be me, but I don't understand the solid strut thing on a Sportster..
It might give you a hardtail ride, but without the 'look' of an actual hardtail.
Seems that it would be better for the backbone to just check around and find some covered shocks to install. I'm sure there are some narrow diameter models out there that would bolt up to the bike.
You would still have the 'look' of a strut, but also have a little spring dampening for the rear suspension.
"You would still have the 'look' of a strut, but also have a little spring dampening for the rear suspension."
I think alot of the appeal of the struts is to get the fender down as low as possible. Not necessarly for the look of the strut. I could be wrong.
I personally dont see why you would want to take away the suspension just to get another inch or 2 down on the tire.
My nightster rides rough enough as is. But to each their own.
Maybe I'm just to old, but I like to RIDE and think nothing of running 300 miles once a week for a hamburger. That just ain't going to happen on a rigid.
+1 I don't get replacing shocks with struts either, other than to rattle your bones to the closest watering hole, or is it Starbucks?
......my cycle is no bar hopper.I like to "RIDE" too
