stupid q about headlight trim rings
I just won this
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Was in the dealership looking at them in person today. I see they have like a little rubber gasket thing on the inside.
Ok, since I won't be getting instructions, Do you take off the ring already on there, or does this go over it?
I did the trim rings on my turn signals and when I took the original trim off there was not even any o-rings. There is now. Supposed to keep moisture out.
the actual glass bulb should be sealed inside there so you dont really need to worry about it as far as i know. Mine took a whole 2 minutes to put on. just the one screw on the bottom. there should be a couple of tabs on the top that fit into the groove to hold it on. Very easy, no mechanical knowledge needed.
