Too much free time mods.....
Well not really mods. persay but subtle improvements.
Lets just say that free time, boredom, cold miserable weather can often result in your bike looking like this:
Pulled my wheels and decided to pull the brake rotors which were a little rusted and worn after 25k miles of use, not that they look all that great in the dull gray rough texture when new either. So I ground the rough texture in the ctr. smooth and then wetsanded 225-2000 grit and polished with mothers (stainless shines up well), stop at a lower grit on the brake surface so it will grip well.
Decided to pull my triple trees and inspect and lube the bearings (which needed it). So while they were off I figured what the heck, why not really polish the dull areas and parts that show to a brilliant shine. But first I filed the casting marks off then sanded them completely with 225-2000 grit to remove scratches then finshed them off with some machine polishing with mothers (I did my fork lowers a couple years ago the same way). Here's some before and after shots during the filing and rough sanding up to washing the polish residue off before reinstalling them (sorry for polish shots are a little dim, but you get the picture). If I decide to keep my narrow glide trees in the future and eventually go to a relocated mini speedo I'll just cut the top tree mounts off which is where my speedo is mounted now with an early style xl/dyna single guage bracket. Who knows, I might even powder coat them eventually.
I've also pulled my rear pulley which will be going out to powder coat this week for some high gloss vivid black. I had stripped and sanded it along with some epoxy paint but was not saitisfied with the finish or durability so I figured I'd do it the right way. I did however epoxy paint my former chrome shock perch covers to go with my already black shocks and fender strut covers I had powder coated last year. While I had the wheels off they also got a thorough chrome polish job since they have never seen more than soap and windex. Also waxed and buffed the tins and parts of the frame and swingarm.
So basically I just did a few no $$ mods. and maintenance to kill some time.
Thanks guys. Gotta do something to pass these past teens to 20 degree days away and what better way than spending quality time with your bike in a heated workshop Now if I had to work in my cold drafty garage it would be out of the question. Just wanted to share what simple things can be done to avoid the winter blues while still spending time with but not necessarily on the bike.
