problem
Old 01-17-2009 | 07:07 PM
New Guy's Avatar
New Guy
Default problem
ok, im stupid to this.
im getting ready to chop my rear fender and im looking for some suggestions.
any pics of chopped rear would be appreciated. i searched and some are too old and the pics are gone and i think i only found a couple threads with actual pics.
im also looking for side mount tag plates with lights.
im wanting to put this one on my 05 883.
http://cgi.ebay.com/ebaymotors/Chopp...mZ370146393004
do i have a 3/4" or 1" axle?
Old 01-17-2009 | 09:23 PM
vegasrock's Avatar
vegasrock
here are pictures of my fender chop before it got repainted. i made my own side mount plate bracket and used LED light bolts that i found on ebay for $15.
Old 01-18-2009 | 08:12 AM
capttawes's Avatar
capttawes
Also check out www.xlforum.net for some pics/info on chopped fenders. there's not much to it really. As for the side mounts the one you listed is cool but I gotta say that Dreamweavers has not had the best rep. (read a lot of posts on the dyna forum about breakage). I run a Road 6 customs mount myself for like $20 and its worked fine the last year or so and 10k miles (you can find them on ebay). I beleive the 06 yr. went to the 1" axle so yours is probably 3/4" but either way the end of the axle where the nut goes on and clip is only 3/4" even on my 1" axle.
Old 01-18-2009 | 09:53 AM
FandA M's Avatar
FandA M
Here's a pic of a fender I did on my Sportster.It's real easy to do.I scribed a line with a grease pencil and cut it.I used a dremmel instead of an angle grinder.It took a little longer ,maybe five minutes,but I gives a much cleaner cut with no paint chipping.This was the first cut.I have since cut it again but have no pics since the cycle is apart now.It looks pretty much the same except I cut the sides out and shortened the strut covers again
Old 01-19-2009 | 11:11 AM
New Guy's Avatar
New Guy
well, i ordered the light and side mount.
gotta buy another dremel and start the chop.
NightTrainRob
Softail Parts
04-02-2012 07:43 PM
spankdog
11-19-2011 12:56 AM
TheeBoy
12-20-2008 12:12 AM
CREEPSHOW
03-13-2008 12:31 PM
clayman
03-29-2007 01:39 AM
Quick Reply: problem
