Speedo Relocation Instructions (My Version)
#61
Where'd you get that handlebar clamp, Slackster?
Hey, I have to thank you for the detailed instructions on the Speedo relocation. It's great with all the step by step pics. I'm about to do it on my Iron, and put the autometer clamp right where you have it, at the gas tank mount. Perfect! So I need to get a black clamp, sort of like the one integrated into my indicator lamp/speedo bracket clamp, and I've been lookin for something exactly like you have. Are you willing to give up the info to a guy over in Japan looking for a clamp? Let me know, as that's the one I've been looking for to no avail. Again, thank and have a good one.
CBB
Sendai, Japan
CBB
Sendai, Japan
#63
Slackster, one more question if you don't mind. When you did your mirror flip, did you have to swivel your turn signals in quite a bit to get clearance for the mirror post?
My bike has the same ball/joint type of turn signal mounts, but was wondering if you can swivel them enough to get clearance for the mirror flip without having to go the turn signal relocation route? Thanks to GPS to for his original speedo relocation walk-thru. All very helpful! To all, a very nice week!
-CBB
-CBB
#64
steve0, you have a used black handlebar clamp like the one's Slackter and GPS used for their speedo relocations? If so, any way you could post a picture? As well, how muchfor the clamp and a cheap ship to Sendai, Japan, zip code 982-0841? Maybe if you throw it in a padded envelope with some bubble wrap, you could ship it air insured for pretty cheap. I got PayPal, too. Thanks a lot, CBB
#65
#66
So SteeveO, what's the word with that clamp? I suppose that when I said, "ship to Japan" the deal fell through. anyway, let me know, as I'm still looking for a good clamp.
And used might just save me some money. Like I said, I got PayPal, so no problems getting a payment to you.
-CBB
-CBB
#67
What kind of clamp do you have, Steve0?
Hey, thanks for the reply. Sorry to bother you when you're busy.
I'm sort of curious as to what kind of clamp you have....since you're asking $60 for a used clamp, I'm sort of assuming that it has the spot for the indicator lights/dummy lights built into it? Or is it just a regular clamp that I'll have to "rig" my dummy lights too using some double sided tape?
The reason I ask is I can get a regular ole OEM black handlebar clamp over here for about 3800yen/$37, so if it is just a plain ole clamp, then I'll save a bit buying over here, but if it's a cool black clamp that sort of matches the Iron look and will take the indicator strip as well, then I'M interested. Like I said, if you can e-mail me some pictures, please do. I can get a lot better idea of what it is and maybe save the both of us some time. I would hate to waste your time anyway. Thanks a lot,
CBB
CBB
#69
What's up everyone? So I've been lurking this thread for a while and decided to try and do it on the cheap...well, cheaper than the 12 bucks for the Auto Meter clamp. Ha.
So I found a stock black handlebar clamp on ebay, like 25 bucks and did the molding tape for the LED's. Used a bit of electrical tape in the front to cover the white. On the side mount clamp, I found a plumbing 3" quick cap, basically a rubber pipe cap with a hose clamp at the hardware store for 5 bucks. Cut the top off with a utility knife and it fits perfect around the speedo and has the rubber seal. I used a bit of the aluminum stock I had left from my coil bracket, bent it to fit and drilled one hole and mounted it to the tank lift bracket and it works pretty damn well. Here's a couple pics. I figure down the road I can always get the Auto Meter set up, I just wanted to see if it was doable.
#70
