Speedo Relocation Instructions (My Version)
Old 11-21-2009, 07:41 AM
diablo666's Avatar
diablo666
diablo666 is offline
In the original post.The wires going to the speedo are under stress from being so tight and turned that way.Either a wire or the speedo will fail from vibration.You need a little slack in them to absorb vibration.
  #92
Old 11-21-2009, 08:30 AM
doktorzoom's Avatar
doktorzoom
doktorzoom is offline
2nd Gear
Originally Posted by Seven
Ok. I've completed the relocation but was changing my handle bar at the same time. I somehow managed to lose a screw holding the brake housing and it fell somewhere in the engine/rear brake area. It must be stuck coz I don't hear a rattle anywhere if I move the bike. I've tried everything to find where it's lodged...only thing left to do is lift the bike upside down and shake it out!
Until I develop the superpower skills to do that, what do I do?
Do I just buy another screw and fit it in, hoping that it will just drop out someday? Or could I be causing more damage?
Help!
Hey Seven...since you've done it recently ..how did u solve the speedo relocation? what size of allen key did u use? and where did u find it?
  #93
Old 11-22-2009, 03:24 PM
congo_usmc's Avatar
congo_usmc
congo_usmc is offline
has anyone used the Auto Meter Part # ATM-3209 with a 4.5 gal tank? does the wider tank obstruct the view of the speedo? does it even fit on there with the wider taNK?
  #94
Old 11-22-2009, 08:16 PM
ccryders's Avatar
ccryders
ccryders is offline
6th Gear
I did the relocate on my 1200 custom. I can see from 20 to 80. I mounted on the front tank bolt also with the summit racing bracket.
  #95
Old 11-23-2009, 12:50 AM
Tike71's Avatar
Tike71
Tike71 is offline
The allen key size is a 3/32"
  #96
Old 11-23-2009, 09:44 AM
congo_usmc's Avatar
congo_usmc
thanks, so you had to spin it sideways? so the top of the speedo was pointing left?
  #97
Old 11-23-2009, 07:32 PM
ccryders's Avatar
ccryders
ccryders is offline
6th Gear
Not really. The side of the tank blocks the lower numbers and the front of the tank blocks everything above 80.
  #98
Old 11-24-2009, 07:55 AM
GrahamOak's Avatar
GrahamOak
GrahamOak is offline
1st Gear
just move it around, theres no exact way to put your speedo, put it where you feel you need to see the speed. its gonna make the custom look alot better. cause i dont know about you, but the pullback risers dont look good with apes, you should deff do the relocation, wasnt hard.
  #99
Old 11-25-2009, 10:05 AM
1200chaos's Avatar
1200chaos
1200chaos is offline
i think the allen screws on the back of the speedo were or are 3/32nds I think it was... it's been awhile.
  #100
Old 11-25-2009, 08:40 PM
gr8stdane's Avatar
gr8stdane
gr8stdane is offline
relocated mine today, followed the instructions. took a couple hours, mainly to paint my new bar clamp, and drilling holes with dull drill bits I used a bracket to extend it out a bit so I can see the whole speedometer. Just used the double sided tape trick for the dummy lights, seemed like the easiest at the time, and looks pretty good.
Attached Thumbnails Speedo Relocation Instructions (My Version)-jd1.jpg   Speedo Relocation Instructions (My Version)-jd2.jpg
Quick Reply: Speedo Relocation Instructions (My Version)
