Vance&Hines straightshot baffles?????
I have V&H straightshots.There are baffles in them.I can see them,but I have no idea what kind they are.I can stick a broom handle all the way to the bend in the pipes.But there are fins at the tip of the pipes.I was just wondering what they were,and how many different kinds V&H makes?????Thanks for any help
2003 883r
2003 883r
The normal straight baffles are what you've got. I pulled mine out after 2 days and replaced them with the quiet baffles. You can't stick a broom all the way through the quiet baffles, but you can the normal ones. The qb's make the sound deeper and throatier. I like it much better. It took away the tinny, whinny sound and made it much nicer on the long rides. Not sure it did anything more for power, but it definetly didn't take away any power. I'd recommend getting the qb's, but that's just my $.02.
So I've been researching baffles and found this old post...
Ultimately I want to change the whole pipe setup as some have suggested but for the time being I've been looking into the baffle options for my pipes. I have the V&H Straightshots and because the bike is a 2003 the standard baffles that come with it are 2.25 inches in diameter according to V&H. Well, I was thinking it might be a good idea to try the new quiet baffles so I called V&H. Found out they don't make the quiet baffles to fit the larger pipe. Seems the newer pipes (2004+) are smaller? Like a quarter inch smaller. So anyway, the question is has anyone found a way to make the quiet baffles (2 in.) work in the older and larger pipe and be reasonably secure? I'd really appreciate any responses, positive or negative. Thanks everyone. Steve
