Best shocks?
Best shocks?
I have an 07 1200 custom with Boss bags. I'd like to upgrade my shocks while remaining compatible with the saddlebags. I've heard progressive 440's and road king shocks are both really sweet. Anyone had any experience with either of these? Or some others that you like? Gracias, amigos.
TLM
TLM
It really depends on your weight and riding style. I tried 12" Progressive 418's and a set of road king shocks on my XL1200n. While both were an improvement over stock neither was what I expected and I still felt a pretty good jolt on certain bumps. I weigh about 190lbs and i prefer a slightly more aggressive style of ride. I would like to refer you to a thread on another forum. There a couple guys have really done alot of research on sportster suspension. One of them in particular found by combining the body of a Roadster shock with the springs off a custom with a spacer to take up the slack of the shorter spring makes a very good shock. I have done this and it made a vast improvemnt over the stock, progressive 418 and road king shocks. Now once again I say for my style and weight. Depending on your weight and style of riding there may be a better way to go.
Here is a link to the thread.
http://xlforum.net/vbportal/forums/s...d.php?t=118153
For what its worth I doubt he's looking to do piggyback resivoir shocks and they definitely wont work with Boss baggs. I'm also pretty darn sure Roadking or other air shocks wont work either as their diameter does not fit the cutout in the bags well.
You can read lots of threads on shocks for darn sure.
I will add this, unless you run with shocks that are about 12.5" the spring rate and travel on shorter ones will only ride marginally better than what you have and no matter the brand or model the results will be the same when running short shocks. I've run 11", 11.5 heavyduty and 11.5" std. spring Progressive 412 shocks and speak from over 24k miles on that assortment. 12.5" length shocks and up not only have more travel but also different spring rates (softer, even in the heavy models) and will ride smoother but will indeed increase the ride hgt. and amt. of space between the fender and tire so its eitehr looks or ride. As for the 440s I've been told by Progressive when I consdiered trying them that the IAS does not work in the shorter lengths and will ride no different than the 412s (same springs) so to take advantage of them you should opt for 12" or longer (their words not mine). They also work best with riders in the 250lb. range vs. lighter folks (again their words).
I think a number of us buy and try a variety of shocks before we just become content with the ride and its bumps/jolts at times
TLM
TLM
I run Progressive 413's in 15" length.
They may not be the chromiest or best looking, but they are the best handling shocks and definitely the best value.
TLM
TLM
